Datasheet TLV2370, TLV2371, TLV2372, TLV2373, TLV2374, TLV2375 (Texas Instruments) - 7
Manufacturer | Texas Instruments |
Description | TLV237x 500-µA/Ch, 3-MHz Rail-to-Rail Input and Output Operational Amplifiers With Shutdown |
Pages / Page | 59 / 7 — TLV2370,. TLV2371. , TLV2372. TLV2373,. TLV2374. , TLV2375. www.ti.com. … |
Revision | F |
File Format / Size | PDF / 2.4 Mb |
TLV2370,. TLV2371. , TLV2372. TLV2373,. TLV2374. , TLV2375. www.ti.com. TLV2375 D, N, and PW Packages. 16-Pin SOIC, PDIP, and TSSOP
TLV2370, TLV2371 , TLV2372 TLV2373, TLV2374 , TLV2375 www.ti.com
SLOS270F – MARCH 2001 – REVISED AUGUST 2016
TLV2375 D, N, and PW Packages 16-Pin SOIC, PDIP, and TSSOP Top View
1OUT 1 16 4OUT 1IN − 2 15 4IN − 1IN+ 3 14 4IN+ V 4 13 DD+ GND 2IN+ 5 12 3IN + 2IN − 6 11 3IN− 2OUT 7 10 3OUT 1/2SHDN 8 9 3/4SHDN
Pin Functions: TLV2375 PIN I/O DESCRIPTION NAME SOIC, PDIP, TSSOP
GND 13 — Ground connection 1IN– 2 I Inverting input, channel 1 2IN– 6 I Inverting input, channel 2 3IN– 11 I Inverting input, channel 3 4IN– 15 I Inverting input, channel 4 1IN+ 3 I Noninverting input, channel 1 2IN+ 5 I Noninverting input, channel 2 3IN+ 12 I Noninverting input, channel 3 4IN+ 14 I Noninverting input, channel 4 1OUT 1 O Output, channel 1 2OUT 7 O Output, channel 2 3OUT 10 O Output, channel 3 4OUT 16 O Output, channel 4 1/2SHDN 8 I Shutdown control, channels 1 and 2, (active low, can be left floating) 3/4SHDN 9 I Shutdown control, channels 3 and 4, (active low, can be left floating) VDD 4 — Positive power supply
TYPICAL PIN 1 INDICATORS Pin 1 Printed or Pin 1 Pin 1 Pin 1 Molded Dot Stripe Bevel Edges Molded “U” Shape
If there is not a Pin 1 indicator, turn device to enable reading the symbol from the left to right. Pin 1 is at the lower left corner of the device.
Figure 1. Typical Pin 1 Indicators
Copyright © 2001–2016, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: TLV2370 TLV2371 TLV2372 TLV2373 TLV2374 TLV2375 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Device Comparison Tables 6 Pin Configuration and Functions 7 Specifications 7.1 Absolute Maximum Ratings 7.2 Recommended Operating Conditions 7.3 Thermal Information: TLV2370 7.4 Thermal Information: TLV2371 7.5 Thermal Information: TLV2372 7.6 Thermal Information: TLV2373 7.7 Thermal Information: TLV2374 7.8 Thermal Information: TLV2375 7.9 Electrical Characteristics 7.10 Typical Characteristics 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Rail-to-Rail Input Operation 8.3.2 Driving a Capacitive Load 8.3.3 Offset Voltage 8.3.4 General Configurations 8.3.5 Shutdown Function 8.4 Device Functional Modes 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Design Requirements 9.2.2 Detailed Design Procedure 9.2.3 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 11.3 Power Dissipation Considerations 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Related Links 12.3 Receiving Notification of Documentation Updates 12.4 Community Resources 12.5 Trademarks 12.6 Electrostatic Discharge Caution 12.7 Glossary 13 Mechanical, Packaging, and Orderable Information
