Adjustable Shunt Regulator Operates Over a -55°C to 150°C Junction Temperature Range
Linear Technology LT1431
Linear Technology announced a new high reliability MP-grade version of the LT1431, a three-terminal adjustable shunt voltage regulator that operates over a -55°C to 150°C junction temperature range. This device has a 100mA sink capability, 0.4% initial reference voltage accuracy and a ±1.4% maximum voltage drift over temperature. On-chip divider resistors allow the LT1431 to be configured as a 5V shunt regulator. By adding two external resistors, the output voltage may be set to any value between 2.5V and 36V. The nominal internal current limit of 100mA may be decreased by including one external resistor.
Linear Technology - LT1431
Active output circuitry provides a very sharp turn-on characteristic, making this device an excellent replacement for Zener diodes in many applications such as onboard regulation, adjustable power supplies, and isolated switching power supplies. The LT1431 MP-grade is available in an SO-8 plastic package and the 1000-piece price starts at $6.49 each.
Features
  • Guaranteed 0.4% Initial Voltage Tolerance
  • 0.1Ω Typical Dynamic Output Impedance
  • Fast Turn-On
  • Sink Current Capability, 1mA to 100mA
  • Low Reference Pin Current
  • -55°C to 150°C Operating Junction Temperature Range
  • Preset 5V Output Voltage or Adjustable Output Voltage from 2.5V to 36V
  • Low ±1.4% Maximum Voltage Drift over Temperature
Applications
  • Linear Regulators
  • Adjustable Power Supplies
  • Switching Power Supplies
linear.com
