World's first handheld SDR debuts
Epiq Solutions Matchstiq
Epiq Solutions, an engineering firm specialising in the development of flexible wireless communications systems, has announced Matchstiq, billed as the world's smallest commercially available software defined radio (SDR) capable of tuning from 300 MHz to 3.8 GHz. Measuring just 5.6 × 12 × 2.3 cm, the Matchstiq combines a broadband RF transceiver with a flexible baseband processing engine running under the Linux operating system.
Epiq Solutions: Matchstiq platform
Matchstiq includes an Atlas-I-LPe computer module developed by iVeia Inc, which combines a Xilinx Spartan-6 LX45 FPGA with a Texas Instruments 1 GHz ARM Cortex-A8 processor running under Linux. This platform supports a wide range of advanced signal processing tasks while consuming as little as 3 watts in typical receive-only use.
Matchstiq Block Diagram
Click to enlarge
When combined with the library of signal processing applications available from Epiq Solutions or other software suites, such as GNU Radio, Matchstiq enables an array of capabilities including operation as a point-to-point data modem, LTE survey tool, or portable spectrum analyzer. A development kit is also available for users who wish to create their own custom applications.
Key Features
  • Single RF transceiver covering 300 MHz to 3.8 GHz
  • Supports RF channel bandwidths up to 28 MHz
  • Integrated CPU/FPGA for signal processing applications
  • Integrated GPS receiver with 1PPS
  • Run-time loadable/executable software applications
  • Full suite of specialty applications available
  • SDK available for custom application development
  • uSD provides up to 32 GB of on-board data and application storage
  • USB interface to host for system access
  • Size: 2.2" × 4.6" × 0.9" (5.58cm × 11.68cm × 2.28cm)
  • Power: <3 W (typical)
  • Optional external rechargeable battery
  • Availability: December 2011
Matchstiq applications
Click to enlarge
RF Specification
Receiver
RF Input
SMB (50 Ω)
Architecture
Zero-IF (direct conversion)
Tuning range
300 MHz to 3800 MHz
Tuning step-size
1 kHz
Tuning time
<2 mS
Pre-select filter bank
sub-octave from 300 MHz to 3800 MHz
Typical noise figure
8 dB
Typical IIP3
-10 dBm
RF gain control range
0 to 25 dB
Baseband gain control range
0 to 30 dB
Baseband configurable low-pass filter
0.75 MHz to 14 MHz
(RF channel bandwidths from 1.5 MHz to 28 MHz)
Typical I/Q balance
>40 dB (with digital correction)
A/D converter sample rate
Up to 40 MHz with 1 Hz resolution
A/D converter sample width
12 bits
Power consumption (stand-alone)
1.1 W
ESD protection at RF input
20 kV (human body model)
Max safe RF level at RF input (at max gain)
-5 dBm
Transmitter
RF Output
SMB (50 Ω)
Architecture.
Tx tuning range
300 MHz to 3800 MHz
Tuning step-size
1 kHz
Tuning time
<2 mS
Baseband transmit gain control range
0 to 31 dB
0.75 MHz to 14 MHz
RF transmit gain control range
0 to 25 dB
Max Tx output power
+10 dBm
D/A converter sample rate
D/A converter sample width
12 bits
1.0 W (@ 0 dBm power output)
Digital Specification
CPU/DSP
TI DM3730 @ 1 GHz (ARMv7/Cortex A8 + TI C64x DSP)
(ARM Cortex A-9 Dual Core in 2Q 2012)
FPGA
(Xilinx Zynq-7000 in 2Q2012)
Non-volatile memory
32 GB (microSDHC card for storage and applications)
RAM
512 MB LPDDR2
Operating System
Linux 2.6.35 kernel (with real-time extensions)
System Interface
microUSB 2.0 OTG (host or device)
Typical Power Consumption (stand-alone)
2 W (dependent on FPGA usage)
GPS Specification
Number of Channels
51 (acquisition), 14 (tracking)
Sensitivity
-161 dBm
Accuracy
<2.5 meters
Hot Start
1 second
Cold Start
29 seconds
RF Input
SMB
Support for active antennas
Yes (3V bias default, additional bias voltages possible)
Data Interface
NMEA sentences over UART (9600 baud, N81)
1 PPS signal
GPS Lock LED indicator
Typical power consumption (stand-alone)
150 mW (acquisition), 84 mW (tracking)
System Reference Clock Specification
Type
Temperature Compensated, Voltage Controlled Crystal
Oscillator (TCVCXO)
Frequency
30.72 MHz
Frequency Accuracy
±0.5 ppm @ 25° C,
±2 ppm from -30° C to +85° C
Frequency Warping
±8 ppm over range of 0.5 VDC to 2.5 VDC
(using on-board D/A converter)
Frequency Aging
±1.0 ppm (first year @ 25° C)
Alternate Clock Input Option
External clock in via U.FL connector
Temperature Sensor Specification
Temperature Sensing Range
-55° C to +125° C
Temperature Accuracy
±2° C from -25° C to +85° C
±3° C from -55° C to +125° C
Power Input Specification
Power Input Connector
Lemo EGG.00.302.CLL (locking)
Power Input Voltage Range
6V to 28V DC
Physical Specification
Dimensions
2.2" x 4.6" x 0.9"
Weight
4 oz
Operating Temperature
0° C to +50° C (without external cooling)
Battery Specification (Optional)
Dimensions
2.2" x 2.2" x 0.9"
Chemistry
Lithium Polymer (Rechargeable)
Capacity
7.4V @ 1000 mAH
Runtime (Typical)
2 Hours
Matchstiq will start shipping in December 2011 with single unit pricing set at USD 4,500.
epiqsolutions.com
