New 650V IGBT Modules for High Performance and Ease of Design
Infineon
Infineon's new series of PIM and sixpack modules features 650V IGBT4 ranging from 50A to 200A. The modules are available in EconoPIM™ and EconoPACK™ 2 and 3 housings. Relying on PressFIT technology, fast and solder-less assembly combined with highest reliability levels can be achieved. Solder pin versions are equally available.
Infineon - IGBT4 EconoPIM, EconoPACK
The new IGBT modules deliver outstanding performance and simplify the design process. The 650V blocking voltage allows for greater safety margins during operation while 10µs short circuit robustness enables designers to use cost-efficient standard driver designs. Leading on-state and switching losses further boost efficiency.
EconoPIM™ and EconoPACK™ 650V IGBT4 modules perfectly complement existing 1200V and 1700V IGBT4 Econo solutions for drive inverters up to 690V.
Econo 2 and 3 IGBT4 650V topologies
Features
  • Compact, lower power module with a height of 17mm
  • 10µs shortcircuit 1 robustness at 150°C
  • 650V collector-emitter voltage (best in class)
  • Higher margin for overvoltage
  • Operating temperature of up to 150°C
  • Higher power cycling capability
  • Soft switching characteristics
  • 1.55V collector-emitter saturation voltage (outperforms competition)
  • Low switching losses (outperforms competition)
  • Solder and PressFIT mounting technology (first vendor)
  • Optimized heat spreading
  • Low stray inductance < 21nH for sixpack configuration
  • Integrated temperature sensor (NTC)
  • RoHS compliant
Applications
  • Industrial general purpose drives, such as compressors, pumps and fans
  • Variable speed drives
  • Servo drives
  • Air conditioning systems
  • Medical applications (e.g. X-Ray)
infineon-designlink.com
