XMC4500 - Unique Infineon Microcontroller Design
Infineon XMC4500
Infineon's new ARM® Cortex™-M4-based, 32-bit XMC microcontroller family was developed to deliver the power needed by industrial designers to meet the challenges of constant innovation and ever-decreasing development cycles.
The family combines Infineon's leading-edge peripheral set with an industry-standard ARM® Cortex™-M4 core to create a powerhouse for energy-efficient industrial applications.
Infineon - XMC4500
XMC4500 is the first product generation in this novel microcontroller family. It is designed to enable extremely energy-efficient products. Thanks to Infineon’s in-depth microcontroller know-how, it combines optimum real-time performance with all the benefits of an industry standard CPU core.
XMC4500 controllers feature a configurable peripheral set that enables systems to be tailored to specific application needs. To capitalize fully on this flexibility, Infineon has launched the third generation of its industry-proven development environment DAVE™. DAVE™ 3 hosts a graphical user interface, low-level drivers, application libraries, an auto code generation engine and interfaces to generic or customer-selected development tools. The infrastructure eliminates the need for standard work, thus saving development time and enabling software developers to focus on truly innovative algorithms in applications. SOP: May 2012.
Features
  • ARM® Cortex™-M4, 120MHz, incl. single cycle DSP MAC and floating point unit (FPU)
  • 1MB eFlash including hardware ECC
  • 160kB RAM
  • 12-channel DMA
  • IEEE 1588 compliant Ethernet MAC
  • USB 2.0 full-speed on-the-go
  • Comprehensive set of timers and PWM, Delta-sigma Demodulator, Position Interface
  • 4x12-bit ADC, 2x12-bit DAC
  • 6x multi-function serial interface modules configurable to SPI, I2C, I2S, UART
  • 3x CAN nodes
  • External bus interface supporting SDRAM, SRAM, NOR-/NAND-Flash and memory-mapped IO devices (e.g. LCD)
  • SD/MMC interface
  • Touch interface & LED Matrix
  • Battery-backed real-time clock with calendar function and timebased or external wake-up capabilities
  • Extended temp range up to 125°C
Applications
  • Renewable energy
  • Logistics
  • Factory Automation
  • Building automation
  • Transportation
  • Medical equipment
