The VLSI Solution VS23S010 is an easy to use SPI SRAM device with the largest capacity on the market. The memory can be accessed via a standard SPI compatible serial bus (1, 2 and 4-bit modes), or via an 8080-type 8-bit parallel bus similar to nand flash devices.
One of the main applications for the VS23S010 is microcontroller RAM extension. Internet streaming applications, which are becoming increasingly popular, will benefit from the large buffer memory provided by VS23S010.
In addition to being used purely as a memory storage device the VS23S010 also contains a pattern generation logic. When VS23S010's RAM is accessed through the SPI bus, it can simultaneously output a repeating memory data pattern through four of its parallel bus pins. This feature significantly reduces the computing requirement of a microcontroller for applications that require periodic output from the memory, such as a video frame buffer.
The VS23S010 is operated from a single voltage with an unforeseen flexible voltage range from 1.5V up to 3.6V. This feature together with the standard 4-wire SPI interface and an industrial temperature range (-40 ... +85 ºC) makes the device both reliable and easy to use for any application requiring additional RAM.
The SPI interface supports single, dual and quad I/O. All of these I/O modes can further support byte-based or sequential byte transfer modes. SPI operation is fast: in quad mode the whole 131,072 × 8-bit memory can be written in 262,176 clock cycles. Using the maximum 36MHz SPI clock the write time of the entire memory is less than 7.3ms.
The VS23S010 is offered in SOIC-16 (300mil) RoHS compatible package. The budgetary volume price of VS23S010 is USD 0.99.
