Logitech TV Cam HD - Skype on your TV
Logitech TV Cam HD
Logitech is offering a video camera on the Russian market, which allows you to communicate with Skype in HD resolution using a large television screen. And the only requirement is the presence of a TV interface, HDMI, everything else Logitech TV Cam HD makes himself, unless of course you have internet at home, which you can connect the device via Ethernet or wireless Wi-Fi.
To work does not need to install any software, you can simply use your existing account on the system or create a new Skype. For video in 720p require a connection to the Internet at a speed of 1.2 Mbit / s.
The camera itself can be mounted on the TV screen, or in any place convenient for you. Wide-angle lens is present during the video to your friend the whole family. With this you can feel free and move around the room. Technology Logitech Fluid Crysta, Carl Zeiss optics and powerful video processor can get crystal clear and sharp video in HD 720p. If necessary, you can increase your companion for the person or what or area in the room. Digital zoom and focusing on specific areas hold the remote control. The camera works well even in low lighting.
Camera Logitech TV Cam HD is equipped with four high-quality microphones, which allow even large rooms to achieve exceptional sound quality from the area in front of the camera, due to highly directional microphones and the system of suppressing background noise and sound reflections from the walls.
The perfect complement to the camera Logitech TV Cam HD is a control panel that makes it easy to receive calls, use the contact list based on the familiar interface Skype. With the Logitech TV Cam HD you do not miss another call, even when TV is turned off due to an external power supply is always possible to monitor incoming calls.
logitech.com
