After the launch of APV/APC-12/16 series, Mean Well further introduced 25W/35W rectangular economical plastic case LED power supplies~ APV/APC-25/35 series. Following the same design concept of APV series with C.V. mode and APC series with C.C. mode, these four new series are non-PFC design, in order to keep the low-cost advantage and to provide users more alternatives while designing the lighting fixtures.
With up to date high frequency switching topology, APV/APC-25/35 series feature with 90~264VAC input range and possess up to 84% of high efficiency, so that they can work between –30~+70°C by only free air convection. APV/C-25 (25W) are not potted while APV/C-35 (35W) are semi-potted for PCB protection and provide the basic ability of anti-moisture, anti-dust as well as heat-conduction purpose. Built-in standard functions include short circuit, overload, over voltage protections, withstand 300VAC surge input for 5 seconds…etc. With IP30 design, these new power units are recommended to apply to indoor LED lighting without the need of high level waterproof and dustproof ability. Typical applications include LED indoor lighting, LED-based decorative lighting, and LED electrical display…etc.
Feature
- 90~264V universal AC input
- Constant voltage design (C.V. mode) for APV series; Constant current design (C.C. mode) for APC series
- Plastic case with 94V-0 fire prevention level
- 84% high efficiency
- Cooling by free air convection
- Isolation class II, no FG
- Protections: Short circuit / Overload / Over voltage
- Low cost, high reliabilty
- 100% full load burn-in test
- Certificates: CE
- Dimension (L×W×H): 84 × 57 × 29.5mm
- 2 years warranty
