Microchip Introduces Volatile Digital-to-Analog Converter
Microchip MCP47A1
Low-Power, Low-Cost 6-bit Volatile DAC With Command Code Features 1.8-5.5V Wide Operating Voltage Range; I2C and SMBus compatibility
Microchip Technology Inc. introduced the volatile MCP47A1 Digital-to-Analog Converter (DAC).  This low-power, low-cost DAC features a 1.8-5.5V wide operating voltage range, and is offered in a 6-pin SC70 package.  The MCP47A1 is ideal for applications in the automotive, audio and industrial markets, such as portable, handheld battery-operated products, and applications such as set-point or offset trimming and sensitive mechanical-trim pot replacement.
Microchip Introduces Volatile Digital-to-Analog Converter MCP47A1
The extended temperature range of -40 to +125 degrees Celsius allows for use in high-temperature automotive and industrial applications.  Additionally, the small SC70 packaging allows for more portable and space-constrained consumer applications.  The MCP47A1 DAC also provides 65 taps, through an I2C™ interface, including taps to both full-scale and zero-scale, providing additional functionality.  Low power consumption extends lifetimes in applications with finite power supplies, and the low cost is suitable for cost-sensitive applications.
Microchip MCP47A1 Block Diagram
“The MCP47A1 is optimized for system power reduction and cost reduction,” said Bryan J. Liddiard, vice president of marketing with Microchip’s Analog & Interface Products Division.  “Because of its extended temperature range, this new DAC can also be used in high-temperature automotive and industrial applications.”
Pricing & Availability
The MCP47A1 DAC is available today for sampling and volume production, at $0.42 each in 5,000-unit quantities. It is offered in a 6-pin SC70 package. For further information, contact any Microchip sales representative or authorized worldwide distributor, or visit Microchip’s Web site at http://www.microchip.com/get/Q2UL. To purchase products mentioned in this press release, go to microchipDIRECT or contact one of Microchip’s authorized distribution partners.
microchip.com
