CoolMOS™ P6 is Infineon’s seventh generation of high-voltage power MOSFETs to be designed in line with the revolutionary superjunction (SJ) principle.
The new CoolMOS™ P6 series combines Infineon's expertise as the leading SJ MOSFET supplier with its innovative strengths in energy efficiency. The resulting P6 technology is easy to use while at the same time ensuring outstanding performance levels in hard and soft-switching topologies (for example, PFC, LLC).
P6 achieves extremely low conduction and switching losses, particularly in light load conditions. This enables switching applications to work more efficiently and designers to create more compact, lighter and cooler devices.
Thanks to its granular portfolio, P6 can also address the specific needs of applications such as servers, PC power supplies, telecom rectifiers and consumer applications while offering the best price/performance ratio currently available on the market.
Features
- Reduced gate charge (Qg)
- Higher Vth
- Good body diode ruggedness
- Optimized integrated Rg
- Improved dv/dt
- CoolMOS™ quality with over 12 years of experience in manufacturing superjunction technology
Applications
- PFC stages for server, telecom rectifier, PC silverbox, gaming consoles
- PWM stages (TTF, LLC) for server, telecom rectifier, PC silverbox, gaming consoles
