Larson Electronics Releases a 277 Volt AC A19 LED Bulb for the Industrial Marketplace
Larson Electronics LED-A19-10-E26
In an ongoing effort to meet the needs of the industrial marketplace, Larson Electronics announced the LED-A19-10-E26 bulb. The unique feature of the Larson Electronics A19 LED bulb, which is a replacement for the standard 100 watt incandescent light bulb, is that it operates on voltages ranging from 120 to 277 VAC.
Larson Electronics - LED-A19-10-E26
The LED-A19-10-E26 fits into standard E26 (US) and E27 (Europe) sockets. With 10 watts of power, the Larson Electronics A19 LED bulb produces 1050 lumens. Designed for harsh environments, the Larson A19 LED bulb operates in temperature ranges from -50 ºC to 85 ºC.
Given that most commercial facilities are wired to the grid at 480 Volts, they automatically have 277 VAC available, so Larson's 277 Volt capable A19 bulb is a logical fit for this marketplace. The lumen output on this A19 LED bulb is at the top of the available choices in the marketplace.
Larson Electronics produces a wide range of LED retrofit bulbs for 120/277 VAC applications and 12/24 VDC applications, including T-series bulbs, PAR38 and PAR46 bulbs.
magnalight.com
