Ronetix introduced the SAMA5D3-CM SODIMM-sized System-On-Module. The SOM is based on the newest Atmel’s ARM Cortex-A5 based SAMA5D3 series processor. The SAMA5D3-CM features 512MB DDR2, 256MB NAND Flash, 16MB NOR Flash, 4MB SPI Flash, 1-Wire EEPROM DS2431 and Gigabit Ethernet PHY. The Ronetix SAMA5D3-CM modules are available now.
The SAMA5D3-CM boards are available with a choice of Atmel SAMA5D31, SAMA5D33, SAMA5D34 or SAMA5D35 processors. All four boards share the same circuit design with minor configuration. The Ronetix CM modules measure only 67 × 40mm. They run Linux 3.6.9 and Android 4.0.
Ronetix SAMA5D3x-CM CPU Module Features
- AT91SAMA5D3x series MCU, 536 MHz ARM Cortex-A5 ARM v7-A Thumb2 processor @ 1.2V
- 850DMIPS at under 200mW
- 512 MB DDR2 SDRAM
- 256 MB NAND Flash
- 16 MB NOR Flash (optional)
- 4 MB Atmel SPI Flash
- 10/100/1000 MBit/s Ethernet
- One-wire 1024-bits EEPROM and 64-bits ROM
- SO-DIMM 200 JEDEC MO-274 module
- Operating temperature 0° to +70°C, storage temperature -40° to +85° C
- RoHS compliant
