New Generation of System Basis Chips (SBCs)
Infineon TLE9266QX TLE9267QX
The latest generation of Infineon’s System Basis Chips (SBC) are monolithic integrated circuits in an enhanced power package. The TLE9266QX and TLE9267QX are the first products in this new generation.
Infineon - TLE9266QX, TLE9267QX
Designed specifically for harsh automotive environments, these devices are targeted at applications that communicate over CAN and LIN such as body controllers, gateway applications and HVAC systems. In particular, they deliver the ESD and EMC performance demanded by automotive OEMs.
The new-generation SBCs deliver high performance with integrated high-speed (HS) CAN and LIN transceivers, multiple low-dropout voltage regulators (LDO) for 5V supply and a 16-bit SPI to control and monitor the device. They also come with a configurable watchdog, limp home outputs and configurable undervoltage protection. Low-power modes make them ideal for applications that are permanently connected to the battery.
A modular approach ensures software and hardware compatibility across the entire family for simplified programming.
Features
  • HS-CAN transceiver compliant with ISO11898-2 and ISO11898-5
  • TLE9267QX HS-CAN transceiver compliant with ISO11898-6 (draft)
  • LIN transceiver compliant with LIN2.1 & LIN2.2 (SAE J2602)
  • Scalable voltage regulator (3.3 or 5V)
  • Independent 5V regulator to supply CAN transceiver or external load
  • 6 high-side switches with independent and programmable PWM timing
  • 2 low-side switches to drive relays
  • 3 wake-up inputs with cyclic sense
  • Very low current consumption in sleep and stop mode
  • High ESD protection and EMC performance
  • Integrated fail-safe functions: watchdog, limp home
  • Revised SPI interface for simplified programming and monitoring functionality
  • Small leadless exposed pad package
Applications
  • Broad range of electronic control units (ECUs) in automotive applications like:
    • Body control modules
    • Climate controls
    • Seat controls
    • Adaptive lighting
    • Parking assistance
    • Door modules
    • Transmission controls
    • Electric power steering
infineon-designlink.com
