The Cubietruck is an upcoming mini-computer with a dual-core ARM Cortex-A7 processor, up to 2GB of RAM, Gigabit Ethernet, and WiFi and Bluetooth built in.
While it’s not the most powerful device of it’s type, the Cubietruck does have a few tricks up it sleeve, including out-of-the-box support for both Google Android and Ubuntu Linux.
The Cubietruck is essentially a PC-on-a-board, which means it won’t come with a case. You can buy or build your own. At 4.3″ x 3.1″ the new computer has many input and output ports and space to build a case that can hold a 2.5″ hard drive or solid state disk.
The system has a microSD card slot, 2 USB ports, HDMI and VGA ports, a headphone jack, a SATA 2.0 interface, and extended pins which you can use for programming, debugging, or connecting peripherals.
Cubiesteam hasn’t announced a launch date or price yet.
Hardware Features:
- AllWinnerTech SOC A20 ARM Cortex-A7 Dual-Core, ARM Mali400 MP2 Complies with OpenGL ES 2.0/1.1
- 1GB/2GB DDR3@480MHz
- HDMI&VGA 1080P display output on-board
- 10M/100M/1G Ethernet
- Wifi+BT wireless connection with antenna on-board
- SATA 2.0 interface support 2.5’ HDD (for 3.5’ HDD, only need another 12V power input)
- Storage solution: NAND+MicroSD or TSD+ MicroSD or 2 × MicroSD
- 2 × USB HOST, 1 × OTG, 1 × Toslink (SPDIF Optical), 1 × IR, 4 × LEDs, 1 Headphone
- Power:DC5V @ 2.5A with HDD, support Li-battery & RTC
- 54 extended pins including I2S, I2C, SPI, CVBS, LRADC × 2,UART, PS2, PWM × 2, TS/CSI, IRDA, LINEIN&MICIN, TVIN × 4
- PCB size: 11cm × 8cm × 1.4mm
