Texas Instruments invents new data converter category
Texas Instruments LDC1000 LDC1000EVM
Inductance-to-digital converter revolutionizes position and motion sensing
Texas Instruments (TI) unveiled the industry's first inductance-to-digital converter (LDC), a new data converter category that uses coils and springs as inductive sensors to deliver higher resolution, increased reliability, and greater flexibility than existing sensing solutions at a lower system cost. Inductive sensing is a contactless sensing technology that can be used to measure the position, motion, or composition of a metal or conductive target, as well as detect the compression, extension or twist of a spring. For more information about this new data converter technology and the industry's first LDC, the LDC1000, visit www.ti.com/ldc1000-pr.
Texas Instruments - LDC1000
Applications for inductive sensing range from simple push buttons, knobs, and on/off switches to high-resolution heart rate monitors, turbine flow meters, and high-speed motor/gear controllers. Given their versatility, LDCs can be used in many different markets, including automotive, white goods, consumer electronics, mobile devices, computing, industrial, and medical.
Key benefits of LDC technology:
  • Higher resolution: Enables sub-micron resolution in position-sensing applications with 16-bit resonance impedance and 24-bit inductance values.
  • Increased reliability: Offers contactless sensing that is immune to nonconductive contaminants, such as oil, dirt and dust, which can shorten equipment life.
  • Greater flexibility: Allows the sensor to be located remotely from the electronics, where PCBs cannot be placed.
  • Lower system cost: Uses low-cost sensors and targets and does not require magnets.
  • Limitless possibilities: Supports pressed foil or conductive ink targets, offering endless opportunities for creative and innovative system design.
  • Lower system power: Consumes less than 8.5 mW during standard operation and less than 1.25 mW in standby mode.
Tools and support
The LDC1000EVM, which includes an MSP430F5528 microcontroller (MCU), is available to evaluate the device and can be purchased today for US$29.00.
Texas Instruments - LDC1000EVM
System designers can create a custom sensor coil and configure the LDC in seconds with TI's new WEBENCH Inductive Sensing Designer. The online tool simplifies the sensor coil design process and provides configuration settings for the LDC based on the coil's characteristics, application requirements and system performance needs. The optimized design can be easily exported to a variety of popular CAD programs, to quickly incorporate the sensor coil into the overall system design.
Package, availability and pricing
The LDC1000 is available to order today in a 16-pin, 4-mm by 5-mm SON package for US$2.95 in 1,000-unit quantities. An automotive-qualified version will be available the first half of 2014.
newscenter.ti.com
