IR's IRS2538DS Control IC Offers a Reliable, Highly Efficient, Cost Effective Magnetic Replacement Ballast Solution
International Rectifier IRS2538DS
International Rectifier introduced a reliable, highly efficient and cost effective control IC for magnetic ballasts used in fluorescent lamps.
The IRS2538DS emulates the behavior of a magnetic ballast control system, leveraging IR’s patented ballast and high-voltage technologies to offer an easy to use, high-performance, cost effective one-chip magnetic replacement ballast solution.
International Rectifier - IRS2538DS
Available in a compact SO8 package, the IRS2538DS utilizes a novel control method to achieve high power factor with ultra-low THD to eliminate the need for a Power Factor Correction (PFC) stage and electrolytic capacitor at the input. The new IC integrates a 600V half-bridge control circuit, bootstrap MOSFET and comprehensive set of protection features to further reduce component count and PCB area, and increase reliability.
The IRS2538DS also features preheat, ignition and running lamp modes, closed-loop lamp current control, fixed pre-heat time (2s typical), adaptive deadtime (0.5us to 1.5us typical), lamp insert auto-restart, micropower start-up (125uA) and an internal 15.6V Zener diode clamp on Vcc.
Specifications
Part Number
Package
VOFFSET
(typ)
VCC
(typ)
IO+/IO–
(typ)
IRS2538D
SO8
600 V
15 V
180 mA / 260 mA
Availability and Pricing
Pricing for the IRS2538D begins at US $0.94 each in quantities of 10,000-units. Production quantities are available immediately. The devices are lead free and RoHS compliant. Prices are subject to change.
irf.com
