Mini-Circuits released generator SSG-6000 with an extended frequency range.
The SSG-6000 offers:
- Expanded frequency range from 25 to 6000 MHz
- 70 dB adjustable output power range from -60 to +10 dBm
- 3 Hz frequency resolution
- 0.25 dB output power resolution
- Triggered or continuous RF pulses with 1 µsec resolution
- Multiple frequency and power sweep options (up, down, bi-directional)
- Frequency/power hopping
- USB control from any PC
The SSG-6000 is supplied with our easy-to-install, easy-to-use GUI control software and API objects for Windows environments with complete programming instructions for 32 and 64 bit Windows and Linux operating systems. It is compatible with most third-party software and programming environments (see list below), allowing easy integration with existing setups.
Like all of our portable test equipment models, the SSG-6000 is small enough to fit in a laptop case.
