Vishay Intertechnology announced that it has extended its TANTAMOUNT® low-ESR TR3 and standard industrial-grade 293D series of solid tantalum surface-mount chip capacitors with higher ratings up to 75 V in the B, C, D, E, V, and W case sizes. The industry's first 75 V molded tantalum capacitors, the Vishay Sprague devices are designed to meet the derating requirements of 50 % rated voltage in +28 V and +35 V applications.
Providing less expensive options for decoupling in 75 V applications and power supplies at +28 V, and DC / DC conversion at +35 V, the devices released today are optimized for sensor, industrial control, and airborne applications, in addition to telecommunications base stations.
The TR3 series offers a high ripple current carrying capability to 2.50 A. The 293D and TR3 capacitors are offered in six and seven molded case sizes, respectively, and feature standard RoHS-compliant tin terminations, with Sn / Pb terminations available upon request. Devices in the C, D, and E case codes are 100% surge current tested.
Part of Vishay’s TANTAMOUNT tantalum capacitor family, the devices released today offer a voltage range from 4 V to 75 V over a temperature range of −55 °C to +85 °C, to +125 °C with voltage derating. The capacitors meet the new EIA-717 international qualification specification — in addition to EIA 535BAAC and IEC QC300801/US0001 — offer a Moisture Sensitivity Level of 1, and are compatible with high-volume pick-and-place equipment to simplify assembly.
Device Specification Table:
Part number
Version
Standard industrial grade
Low ESR
Capacitance
0.10 µF to 1000 µF
0.47 µF to 1000 µF
Tolerance
± 5 %, ± 10 % , ± 20 %
± 10 %, ± 20 %
Voltage rating
4 VDC to 75 VDC
4 VDC to 75 VDC
Min. ESR @ +25 °C and 100 kHz
0.20 Ω
0.035 Ω
Max. ripple current at 100 kHz
0.06 A to 0.87 A
0.10 A to 2.50 A
Operating temp.
-55 °C to +125 °C
-55 °C to +125 °C
Case codes
A, B, C, D, E, and V
A, B, C, D, E, V, and W
