Avago AFBR-83CDxxZ is a pluggable 12-channel, parallel optics CXP Active Optical Cable
Avago AFBR-83CDxxZ
The Avago AFBR-83CDxxZ is a pluggable 12-channel, parallel optics CXP Active Optical Cable (AOC) for multi-channel 12.5Gbps proprietary interconnect, 100 Gigabit Ethernet (100 GbE) and 12×10 G InfiniBand (IB) QDR applications.
The AFBR-83CDxxZ is designed to operate over multimode fiber systems using a nominal wavelength of 850 nm. The electrical interface uses an 84-contact edge type connector. The AOC incorporates Avago Technologies' proven integrated circuit.
Avago AFBR-83CDxxZ
Features
  • Up to 150 Gbps of aggregate bandwidth
  • 3W max power consumption per end
  • Hot pluggable
  • 0 to +70 °C case temperature operating range
  • Compliant to SFF-8642 and IBTA CXP MSA
  • Two Wire Serial (TWS) with masable interrupt
  • Full diagnostic monitoring functions
Applications
  • 12.5 Gbps Proprietary Interconnects
  • 100 GbE and IB-QDR / IB-DDR / IB-SDR Interconnects
  • Data Aggregation, Backplane and Proprietary Protocol and Density Applications
  • Datacom/Telecom Switch & Router Connections
avagotech.com
