Avago releas Optical Isolation Amplifier in 14.2 mm Creepage/Clearance Stretched SO8 Package
Avago ACNT-H790
The Avago ACNT-H790 is a high-linearity optically isolated amplifier device in 14.2 mm wide creepage and clearance, designed for current and voltage sensing applications in systems such as motor drives and renewable energy inverters. In a typical motor drive implementation, the ACNT-H790 can be used to sense a voltage drop across a sense resistor. A differential output voltage that is proportional to the current across the resistor is created on the other side of the optical isolation barrier.
Avago ACNT-H790
The ACNT-H790 has ±3% gain tolerance and offers wide 14.2 mm creepage and clearance with a common-mode transient immunity of 15 kV/µs, which provides the precision and stability needed to accurately monitor motor current in noisy motor control environment. Accurate current monitoring enables smoother motor control (less “torque ripple”) for various types of motor applications.
The ACNT-H790 operates on a single 5 V supply and provides excellent linearity with an SNR of 60 dB. With 200 kHz bandwidth and 1.6-µs fast response time, the device captures transients in short circuit and overload conditions.
Features
  • 3% Gain Accuracy
  • -50 ppm/°C Low Gain Drift
  • 0.6 mV Input Offset Voltage
  • 0.05% Excellent Linearity
  • 60 dB SNR
  • 200 kHz Wide Bandwidth (typ)
  • Operating Temperature Range: -40 °C to +105 °C
  • Advanced Sigma-Delta A/D Converter Technology
  • 0.5 mm Distance Through Insulation (DTI)
  • 15 kV/µs Common-Mode Transient Immunity
  • Compact Stretched SO-8 Package with 14.2 mm Creepage and Clearance
  • Safety and Regulatory Approvals (pending):
    • - IEC/EN/DIN EN 60747-5-5: 2262 VPEAK Working Insulation Voltage
    • - UL 1577: 7,500 VRMS per Minute Double Protection Rating
    • - CSA: Component Acceptance Notice #5
Applications
  • Current Sensing & Voltage Sensing in AC and Servo Motor Drive
  • Mid-Voltage Drives
  • Solar Inverters, Wind Turbine Inverter
  • Industrial Process Control
  • General Purpose Analog Signal Isolation
  • Hall Effect Current Transducer Replacement
avagotech.com
