AVX Corporation has introduced the worlds smallest and lowest profile tantalum capacitor: the new sub-millimeter 0201 TACmicrochip. Measuring only 0.6mm × 0.35mm × 0.35mm, the new 0201 E case TACmicrochip Series SMD tantalum capacitors deliver high CV (0.47F / 6.3V) and low leakage (0.01CV) in an extremely small package, as well as exhibit all of the standard benefits of tantalum technology, including: inherent immunity to piezoelectric noise and higher stability, higher reliability, and higher temperature performance than comparable MLCCs.
Electrically and mechanically robust, TACmicrochip Series capacitors provide long lifecycle performance ideal for use in miniature, wearable medical devices, audio and power amplifier modules, and as coupling/decoupling capacitors in handheld electronics. The new 0201 E case TACmicrochip capacitors extend the series application range to include PCB embedded electronics applications, including near field communication (NFC) systems and smart cards, such as: bank cards, SIM cards, identification cards, and access control cards.
