u-blox combines Wi-Fi and Bluetooth in very compact, host-based automotive client and access point module
u-blox ELLA-W1 ELLA-W131 ELLA-W133 ELLA-W161 ELLA-W163
u-blox announces full production availability of the ELLA-W1 series of compact, automotive-grade, multiradio modules. The modules promise predictable, reliable results and easy implementation of in-car wireless connectivity. Applications include hands-free telephony, in-car hotspots, rear view cameras and graphical user interface (GUI) mirroring.
u-blox - ELLA-W1
ELLA-W1 is a series of ultra-compact, host-based, short-range transceiver modules offering both simultaneous and independent communications over Wi-Fi 802.11a/b/g/n, Bluetooth V3.0 + HS and Bluetooth V2.1 + EDR. Each module has an integrated MAC, baseband processor and RF front end, and connects to its host via an SDIO 2.0 interface. The dual-band Wi-Fi versions (2.4 GHz and 5 GHz) minimize interference problems from the crowded 2.4 GHz band. The modules operate simultaneously in client (STA) and access point (AP) mode, the latter enabling up to 8 Wi-Fi clients to be connected concurrently.
The ELLA-W1 is a surface-mount module with a 14.8 mm × 14.8 mm footprint and 2.5 mm height. ELLA-W1 modules feature best-in-class radio performance, an operating temperature range of –40 °C to +85 °C, automotive qualification to VW 80000/ISO 16750-4, and European, US, and Canadian certifications.
Engineering samples and development kits are available now.
Host-based multiradio modules with Wi-Fi & Bluetooth
Module
Wi-Fi
2.4 GHz
Wi-Fi
5 GHz
Wi-Fi
IEEE 802.11
Bluetooth
qualification
Antenna
pads
b/g/n
v3.0+HS
1
b/g/n
v3.0+HS
2
a/b/g/n
v3.0+HS
1
a/b/g/n
v3.0+HS
2
