ZMDI announces the ZAMC4100, an intelligent actuator and motor controller IC with integrated motor drivers.
ZMDI’s ZAMC4100 addresses the growing demand for intelligent actuator/motor control in industrial, medical and automotive applications, and it is ideal for use where a small form factor is required or external components must be minimized. In a single compact 9 × 9 mm QFN package, the ZAMC4100 integrates an ARM® Cortex™-M0 microcontroller (trademark of ARM, Ltd.); eight power stages with integrated MOSFETs; SPI, UART and LIN2.1 communication interfaces; eight general-purpose digital input/output (I/O) pins; and four general-purpose analog inputs.
Key Features of the ZAMC4100:
- Embedded ARM® Cortex™-M0 microcontroller
- Four integrated low RDSON half-bridge drivers
- Four integrated low RDSON high-side switches
- Wide input voltage range: 6 V-18 V (withstands load-dump conditions up to 40 V)
- Embedded SPI, UART and LIN 2.1 interfaces
- Auto-dimming electrochromatic mirror feature
- Extensive fault protection and error handling
- AEC-Q100 qualified
- Compact 9 mm × 9 mm QFN package
Applications
- Automotive applications
- Home appliances
- Medical equipment
- Security systems
- Industrial automation
Evaluation kits and application boards are available including software development kit, GUI and hardware interface.
ZAMC4100 Application Board. |
Availability
The ZAMC4100 is in full production. Parts, samples and evaluation kits are available directly via ZMDI regional offices.
