New Vishay Intertechnology Ceramic Disc Capacitors Increase Reliability and Save Space With High Pulse Strength to 10 kV in Reduced Sizes
Vishay VY1 Compact
Vishay Intertechnology announced that it has extended its popular VY1 series of AC-line-rated ceramic disc safety capacitors with new devices offering reduced sizes and higher pulse strength up to 10 kV. With body diameters down to 7.5 mm, devices in the Vishay BCcomponents VY1 Compact series are designed to save space while providing higher reliability for Class X1 (760 VAC) and Y1 (500 VAC) applications in accordance with IEC 60384-14.3, 3rd edition.
Vishay VY1 Compact
Featuring Y5U ceramic dielectrics, the VY1 Compact series is optimized for RFI and AC line filtering applications in power supplies, power and smart meters, white goods, and consumer electronics. The capacitors offer a capacitance range from 470 pF to 4700 pF — with tolerances of ± 20 % — over a temperature range of -40 °C to +125 °C.
The devices released today consist of a copper-plated ceramic disc with tinned copper-clad steel connection leads offering 0.6 mm diameters. VY1 Compact series capacitors are available with vertical (inline) kinked leads or straight leads with spacing of 10 mm or 12.5 mm. RoHS-compliant and halogen-free, the devices’ encapsulation is made of flame-resistant epoxy resin in accordance with UL 94 V-0.
Samples and sample kits of the VY1 Compact series are available now. Production quantities are available now, with lead times of 8 to 10 weeks for larger orders.
