Microsemi Launches Best-in-Class Low Capacitance Transient Voltage Suppression Diodes
Microsemi 1N8149 1N8182 1N8149US 1N8182U
150 Watt Hermetic TVS Solutions Provide Ultimate Protection for Avionic Data Network Applications
Microsemi Corporation announced a unique new series of patented, ultra-low capacitance power transient voltage suppression (TVS) diode products. Leveraging the company's 50-year heritage in high reliability TVS technology and its unique radio frequency (RF) PIN diode expertise, the new devices provide protection of high speed data lines and other applications where the threat requirement's magnitude greatly surpasses the capability of other typical low capacitance TVS devices for Ethernet protection and other data interfaces with speeds up to 500 megabits per second (Mbit/s).
Microsemi - 1N8149 … 1N8182 и с 1N8149US … 1N8182US
The new 1N8149 to 1N8182 and 1N8149US to 1N8182US surface mount low capacitance TVS diode products are available as 150 watt (W) peak pulse power at 10/1,000 microseconds with very low capacitance of only four picofarads (pF) maximum. The 150 W TVS diodes equate to greater than 1,000 W at 8/20 microseconds and are offered in voltages ranging from 6.8 volts (V) to 170 V. They also comply with high-end industrial and avionics electrostatic discharge (ESD), electrical fast transient (EFT) and lower level lightning threats in accordance with IEC61000-4-2, IEC61000-4-5 and RTCA-DO160 specifications. Higher power ratings of 500 W at 10/1,000 microseconds with low capacitance are in development for even higher transient threats.
Microsemi's TVS diodes provide aircraft and other electrical systems with critical protection by going into avalanche breakdown within no more than a few nanoseconds after a strike, clamping the transient voltage and routing its current to the ground.
Microsemi: Continued Leadership in TVS Devices
Microsemi TVS devices have been deployed across major commercial airframes that are currently in use worldwide throughout the industry. The company's TVS products are also used in multiple engine control units and actuator controls, as well as a variety of power distribution, environmental control, communications and instrumentation systems.
1N8149 to 1N8182 and 1N8149US to 1N8182US surface mount TVS series key features include:
  • 150 W peak pulse power at 10/1000 microseconds
  • 1,000 W peak pulse at 8/20 microseconds
  • Capacitance: < 4 pF
  • Screening to JANTXV per MIL-PRF-19500 available
  • Breakdown voltages: from 6.8 V to 170 V
  • Finish: ROHS e3 and non e3
  • Halogen-free
Availability
Microsemi's 150W series of low-capacitance TVS diodes are available for all screening levels and are housed in void-less hermetically-sealed axial and surface mount glass packages.
