Interface independent voltage domains with Silego Technology’s 1.6 mm × 1.6 mm 8-GPIO SLG46121V GreenPAK 3 programmable mixed-signal IC
Silego Technology announces the second product in a new class of GreenPAK (GPAK) Mixed-signal Matrix ICs. The Dual Supply SLG46121V expands Silego’s industry leading position in Configurable Mixed-signal ICs (CMICs).
Silego’s smallest member of the GPAK 3 family of NVM programmable devices now features dual supply capability allowing designers to flexibly interface two independent voltage domains using the programmable logic, timing, and analog resources available in all GreenPAK 3 family devices.
The SLG46121V is the second of many planned Dual Supply GPAK products on the Silego roadmap. It features analog comparators, look-up tables, counters, flip-flops, and more. The SLG46121V is available in a tiny 1.6 × 1.6 × 0.55 mm 12-pin STQFN.
Target Applications include:
- Consumer Electronics
- Portable: Tablets, Smartphones, Notebooks
- PCs and PC peripherals
- Wearables
- Commercial and Industrial Electronics
- Servers
- Embedded PCs
- Data Communications Equipment
