TI's TMS320C24xTM digital signal controllers leverage Field Orientated Control in three-phase asynchronous motor for low-cost, algorithm-based speed control
May 24 2004 - Ariston, one of the leading brands of Merloni Elettrodomestici, and Texas Instruments Incorporated (TI) announced that TI's digital signal processing (DSP) based TMS320C24x controllers are enabling sophisticated motor control for reduced noise levels and improved washing efficiency in Ariston's Super Silent line of washing machines. Using TI's low-power controllers, leading white goods manufacturer Merloni Elettrodomestici has implemented a more efficient three-phase alternating current (AC) motor with Field Oriented Control (FOC) in its designs. (For more information on TI's TMS320C24x, see www.ti.com/merlonipr.)
Merloni Elettrodomestici's solution in based on TI's TMS320LF2401A digital signal controller, which is a low cost 16-bit, 40 MIPS fixed-point DSP-based controller featuring an integrated single-cycle multiplier, seven pulse width modulation (PWM) variable frequency and dead-time ports, five ultra-rapid 10-bit analog to digital converters (ADCs), an impulse capture circuit with a 16-bit timer and asynchronous serial communication. Integrated Flash memory allows re-programmability during the development phase and in the field, which satisfies low cost constraints and speeds time to market. A low cost, pin compatible ROM version designed specifically for appliance applications is also available.
Along with the reduction in noise and increase in efficiency, users will also experience a reduction in operating costs due to the inherent efficiency of the AC motor combined with the flexibility to run more complicated field-oriented based algorithms, allowing for better motor optimization with various loads.
TI TMS320C2000TM digital signal controllers make control easy
TI has developed the most comprehensive line of control solutions available by providing the industry with the highest performance and most code-efficient controllers. The C2000 platform of digital signal controllers sets the standard for performance with up to 150 MIPS of DSP performance and microcontroller peripheral integration of flash memory, ultra-fast analog to digital converters (ADC) and robust CAN modules. With TI's powerful and cost-effective C2000 controller platform, designers now have the tools to advance their innovations and reduce time to market as well as system costs.
