IXYS Announces New 60 Volt, Dual, Normally Open Solid State Relay With Highest Current rating in an SOIC Package
IXYS CPC2907B
CPC2907B High Current Relay Provides 4000 Volts of Input to Output Isolation in an SOIC Package
IXYS Integrated Circuits Division (ICD), Inc., an IXYS Company announced the immediate availability of the CPC2907B, a dual, normally open (1-Form-A), 60 Volt, 2 Amp Solid State Relay (SSR) that comprises two independent, optically coupled, bidirectional MOSFET switches. The CPC2907B is the first dual power relay offered by IXYS ICD and features an ultra-low 150 milliohm on-resistance. This dual power relay is the industry’s highest rated load-current device in a surface mount IC package.
IXYS - CPC2907B
This dual OptoMOS relay provides a more compact design solution than discrete single-pole relays in a variety of applications, saving board space by incorporating both switches in a single 8-pin surface mount package. In single pole mode, each switch is capable of 2 Amps continuous load current at 25 degrees Centigrade. Concurrent operation of both poles allows up to 1.7 Amps continuous load current through each switch, with an input to output isolation of 4000 Vrms. Each switch operates with a 5 mA LED input control current.
The CPC2907B meets the following approvals:
  • UL Recognized Component: File E69938,
  • CSA Certified Component: Certificate 1175739
  • EN/IEC 60950-1 Certified Component: TUV Certificate B 13 12 82667 003.
Typical applications include security, instrumentation, data acquisition, medical equipment-patient/equipment isolation, and industrial controls.
The CPC2907B is available in an 8-Pin Power SOIC package.
Pricing and Availability
Production quantities of the CPC2907B are immediately available. Pricing for OEM quantities of 25KU is $3.90.
