Intersil Corporation announced the ISL78010, an automotive-grade TFT-LCD power supply IC. This device is AEC-Q100 rated, fully ISO/TS 16949:2002 compliant and operates over the automotive temperature range (-40 C to +105 C). It is highly-integrated to improve performance and reduce costs associated with powering 7-inch to 15-inch displays. The ISL78010 provides enhanced reliability against transients with its higher voltage capability that protects against stray capacitance and parasitic inductances caused during switching.
The ISL78010 is designed to deliver up to 20 V of boost voltage necessary for mid-size display panels and is available in TQFP package for improved reliability against vibration as well as accommodating visual inspection of pins during board manufacture.
Pricing and Availability
The ISL78010 is available now in a 32-lead TQFP, 5 mm x 5 mm package and is priced at $1.90 each in 1,000-unit quantities.
