Fairchild Semiconductor Introduced New Power Amplifier for WiMax and WiBro Applications
Fairchild FMPA2300
The FMPA2300 power amplifier from Fairchild Semiconductor is designed for high performance WiMax and WiBro applications in the 2.3-2.4 GHz frequency band. The low profile 8 pin 3 x 3 x 1mm package with internal matching on both input and output to 50Ω minimizes next level PCB space and allows for simplified integration. The PA¡¯s low power consumption and excellent linearity are achieved using our InGaP Heterojunction Bipolar Transistor (HBT) technology.
FMPA2300
  • 25 dB small signal gain
  • 30 dBm output power @ 1dB compression
  • 16.5% PAE at 22 dBm modulated power out
  • 2% EVM at 22 dBm modulated power out
  • 3.4 V collector supply operation
  • 2.85 V reference supply operation
  • Lead-free RoHS compliant 3 x 3 x 1mm leadless package
  • Internally matched to 50 Ω and DC blocked RF input/output
  • Optimized for use in 802.16e applications
