The reference design contains four IRF6609 20V, 2mOhm DirectFETTM MOSFETs in parallel to create a 0.5mOhm effective RDS(on) for a high efficiency ORing circuit with fast fault detection and reaction time of 130ns.
The "FET Check" feature is enabled in this reference design, and allows real-time"FET-good" checking for extra fault protection and the highest possible reliability for high power systems.
Active ORing is a key efficiency requirement for many high-end systems requiring maximum up-time, such as carrier-class communication equipment, telecom and datacom system servers. IR's IR5001S IC is ideal for applications such as high reliability server and storage systems where "N+1" redundant power supplies feed into a central load.
Part Number | Rail Voltage (V) | Current (A) | Equivalent RDS(on) (mohms) | Featured Part | Description |
IRAC5001-HS100A | +12 | 100 | 0.5 | IR5001 | +12V, 100A, 0.5mohm Active ORing Reference Design |
Availability and Pricing
The IRAC5001-HS100A is available immediately. Pricing is US $250 each. Pricing is subject to change.
