Stretchable silicon could be next wave in electronics
Researchers at the University of Illinois at Urbana-Champaign have developed a fully stretchable form of single-crystal silicon with micron-sized, wave-like geometries that can be used to build high-performance electronic devices on rubber substrates.
Functional, stretchable and bendable electronics could be used in applications such as sensors and drive electronics for integration into artificial muscles or biological tissues, structural monitors wrapped around aircraft wings, and conformable skins for integrated robotic sensors, said Rogers, who is also a Founder Professor of Engineering, a researcher at the Beckman Institute for Advanced Science and Technology and a member of the Frederick Seitz Materials Research Laboratory.
To create their stretchable silicon, the researchers begin by fabricating devices in the geometry of ultrathin ribbons on a silicon wafer using procedures similar to those used in conventional electronics. Then they use specialized etching techniques to undercut the devices. The resulting ribbons of silicon are about 100 nanometers thick -- 1,000 times smaller than the diameter of a human hair.
In the next step, a flat rubber substrate is stretched and placed on top of the ribbons. Peeling the rubber away lifts the ribbons off the wafer and leaves them adhered to the rubber surface. Releasing the stress in the rubber causes the silicon ribbons and the rubber to buckle into a series of well-defined waves that resemble an accordion.
As a proof of concept, the researchers fabricated wavy diodes and transistors and compared their performance with traditional devices. Not only did the wavy devices perform as well as the rigid devices, they could be repeatedly stretched and compressed without damage, and without significantly altering their electrical properties.
Besides the unique mechanical characteristics of wavy devices, the coupling of strain to electronic and optical properties might provide opportunities to design device structures that exploit mechanically tunable, periodic variations in strain to achieve unusual responses.
