Linear Technology Announces Tiny Micropower Precision Series References In DFN Package
Linear Technology LT6660
Linear Technology Corporation announces the LT6660, the industry's first precision series voltage reference to use the tiny 3-lead 2mm x 2mm DFN package. These compact devices combine 0.2% initial accuracy and 20ppm drift with micropower operation and require less than half the space of the SOT-23 package. Furthermore, the LT6660 does not require an output compensation capacitor – a key advantage where PC board space is at a premium or fast settling is required.
LT6660
The LT6660 accepts input voltages up to 30V and can withstand reverse-battery conditions. The output voltages include 2.5 V, 3 V, 3.3 V, 5 V and 10 V. With a dropout of only 900 mV, this tiny device is also ideal for precision regulator applications since it can supply up to 20 mA of current. Since it needs no output compensation capacitor, the LT6660 is also suited to applications with intrinsic safety requirements.
  • 3-Lead 2mm × 2mm × 0.75mm DFN Package
  • No Output Capacitor Required
  • Low Drift: 20ppm/°C Max
  • High Accuracy: 0.2% Max
  • Low Supply Current
  • 20mA Output Current Guaranteed
  • Reverse-Battery Protection
  • Low IR Reflow Induced Stress: 0.02% Typ
  • Voltage Options: 2.5V, 3V, 3.3V, 5V and 10V
  • Space-Saving Alternative to the LT1460
The LT6660 is in full production, with prices starting at $0.88 each in 1,000-piece quantities.
