Bosch launches BMA400 ultra-low power accelerometer for wearables and IoT applications
Bosch BMA400
  • Significantly enhanced battery life for always-on devices
  • Ultra-low power consumption combined with high performance
  • Intelligent power management for battery-powered devices
  • Built-in step counter drawing only 4 μA
  • BMA400 received CES 2018 Innovation Award
Bosch Sensortec is launching the BMA400, an ultra-low power acceleration sensor for wearables and Internet of Things (IoT) applications. The BMA400 draws ten times less current than existing accelerometers while delivering solid high performance. Its greatly reduced power demand significantly extends battery lifetime, especially on coin cell-powered devices. These qualities have won the BMA400 acceleration sensor from Bosch Sensortec a CES 2018 Innovation Award in the category Embedded Technologies.
Bosch - BMA400
Ultra-low power plus high performance
Usually, accelerometers have to choose between low power and high performance. The BMA400 now offers the best of both worlds: its combination of low power consumption, outstanding performance and advanced features is unrivalled by any other device in the market today – by a wide margin.
Due to continuous measurement, the sensor's high-quality measurement signal has precisely defined cutoff frequencies, making it very resistant to vibrations. This is particularly useful in IoT use cases such as smart home security systems, where the BMA400 can distinguish between real alarm situations like broken glass and false signals coming from random vibrations. Therefore, false alarms triggered by vibrations coming from the outside environment, such as construction works, are easily prevented.
Intelligent power management for battery-driven devices
Due to its ultra-low current step counter at only 4 µA and intelligent power management features like built-in activity recognition, the BMA400 can effectively help wearable devices such as fitness bands, smart clothes, watches and activity trackers to achieve unprecedented battery life.
To further extend battery life, the BMA400 wakes up automatically only when it detects motion and goes back into sleep mode when the motion recedes. This function finds its use especially in ultra-low-power IoT applications powered by coin cells, i.e. smart window sensors in indoor climate control or security systems.
The small size of only 2.0 × 2.0 × 0.95 mm3 and the integrated plug and play step counter make the new BMA400 acceleration sensor easy to design into various applications. This decreases time-to-market, simplifying the addition of step counting functionalities to new types of wearables such as regular watches and jewelry, to give new products the leading edge.
Additional product features
With its built-in voltage regulator, the BMA400 delivers stable performance over a wide supply voltage range. It offers flexible device tuning for power consumption, noise and ODR (output data rate) parameters. The BMA400 has a current consumption of 14 µA at highest performance, continuous measurement and a noise density of 220 µg/√Hz. This falls to just 1 µA and below in the ultra-low power self-wake-up mode. The new sensor further includes a large FIFO of 1 KB.
Availability
The BMA400 will be available for OEMs and distributors starting in June 2018. C-samples for OEMS are available on demand.
