GaN Systems made public the 120 A, 650 V GaN E-HEMT, extending its leadership with the industry’s most powerful line of high performance GaN transistors. Power levels continue to rise creating the need for higher operating current. The numerous advantages of GaN can be applied to much higher power levels today in the automotive, industrial, and renewable energy industries.
Gan Systems’ 120 A, 650 V GaN E-HEMT increases the power density of 20 to 500 kW power conversion systems, including automotive traction inverters, very high power on-board chargers (OBC), large-scale energy storage systems, and industrial motor drives. This transistor, with twice the current capability of GaN Systems’ highest rated current part, allows customers to effectively double the power processing for the same volume.
The product (GS-065-120-1-D), sold as a die to customers building modules, is the lowest RDS(on), highest current 650 V GaN HEMT in the power semiconductor industry. Modules are an important form factor in high power electronics constituting up to 40 percent of the market based on form factor. Customers will use this die product in half-bridge, full-bridge, and six pack module topologies to create enhanced, high-power designs.
“This is the most pivotal GaN product on the market to be optimized for modules and is compatible with both embedded and traditional module technology,” stated Jim Witham, CEO of GaN Systems. “As an extension of our flagship product, it encompasses all the benefits of GaN technology and our approach to GaN power transistors – ease of use, high power density, and high efficiency – enabling power systems that are smaller in size and lower cost with unprecedented power levels.”
Evaluation modules
The GSM-065-120-1 and GSM065-240-1 evaluation modules are available to facilitate evaluation of the GS-065-120-1-D die. Two versions of the evaluation module are presently being offered:
- The 120A GSM-065-120-1-N-0 contains one single GS-065-120-1-D;
- The 240A GSM-065-240-1-N-0 contains two GS-065-120-1-D, connected in parallel for higher current applications and as a demonstration vehicle for general paralleling of the GS-065-120-1-D.
The GSM-065-120-1 evaluation module. |
