Long creepage distance and wide operating temperature range are ideal for demanding industrial applications
Toshiba Electronics Europe announced the launch of a new high-speed IC-Photocoupler for MOSFET gate signal insulation. The TLP2735 is Toshiba's first photocoupler to incorporate an under voltage lockout (UVLO) function with hysteresis.
UVLO reduces the photocouplers susceptibility to noise that is often generated in power supply cables, and can prevent malfunctions at switch on. With an isolation voltage of min. 5 kVrms between the input and output, as well as compliance with the IEC60747-5-5 photocoupler safety standard, the new TLP2735 is suitable for all applications that require high levels of insulation performance.
TLP2735 Internal Circuit. |
The operating power supply voltage in the output side covers the 9 to 20 V range, ideally suited to MOSFET gate voltages. The high power supply voltage means that the device can also be used for IPM input insulation.
The TLP2735 offers a short propagation delay of 100 ns (max) and a data transfer rate of 10 Mbps.
The device is housed in a low profile SO6L surface mount package with a max. height of 2.3 mm, that provides creepage and clearance distances of min. 8 mm, supporting reinforced insulation requirements. In addition, with an operating temperature range of –40 to 125 °C, the device is highly suited to rugged industrial applications.
