Fujitsu has launched a 64-Kbit FRAM Guaranteed to Operate as low as -55 °C
Fujitsu MB85RS64TU
Optimal for applications in industrial machinery that require high reliability in extremely cold environments
Fujitsu Semiconductor announced that it has developed the MB85RS64TU, a 64-Kbit FRAM. This memory is capable of operating at temperatures as low as –55 °C, a first for the Fujitsu's family of FRAM non-volatile memories. Mass-produced products are currently available.
Fujitsu - MB85RS64TU
This product features a wide power-supply voltage range from 1.8 V to 3.6 V, and lower operating temperature as low as –55 °C – lower than that of competitive memories. Because it guarantees 10 trillion read/write cycles across the full temperature range, the product is optimal for industrial machinery such as equipment or machinery used to excavate natural gas and oil in extremely cold regions. The MB85RS64TU is suited for general industrial applications such as measurement equipment, flow meters, and robots.
For approximately 20 years, Fujitsu Semiconductor has mass-produced FRAM non-volatile memory products featuring high-speed write operation, high read/write endurance, and low power consumption. Especially, the guaranteed read/write cycles of the FRAM product is 10 trillion cycles, which is about 10 million times that of competitor non-volatile memory EEPROM. Therefore, Fujitsu FRAM products have been adopted for industrial applications requiring frequent data re-writing such as real-time data logging and 3D positioning data log.
The MB85RS64TU operates with a wide power-supply voltage range from 1.8 V to 3.6 V, at a maximum frequency of 10 MHz through an SPI interface, in temperature environments from –55 °C to 85 °C.
The FRAM product is already available in the industry-standard 8-pin SOP package, making it easy to replace EEPROM in 8-pin SOP. In addition, 8-pin SON (Small Outline Non-lead) packages with very small dimensions of 2.00 × 3.00 × 0.75 mm are also available. The mounted surface area for SON is only 30% of that of the SOP, and mounting volume is only 13% of that of the SOP.
Key Specifications
  • Density (configuration): 64 Kbit (8K × 8 bit)
  • Interface: SPI (Serial Peripheral Interface)
  • Operating frequency: 10 MHz max
  • Operating voltage: 1.8 V to 3.6 V
  • Operating temperature range: –55 ° C to +85 °C
  • Read/Write endurance: 10 trillion times(1013 times)
  • Package: 8-pin SOP, 8-pin SON
