Toshiba releases new three-phase brushless fan motor driver IC
Toshiba TC78B025FTG
New device has a closed loop rotation speed control function
Toshiba Electronics Europe announced the launch of the TC78B025FTG, a three-phase brushless motor driver IC with a rotation speed control (closed loop control) function. The new device is intended for small fan applications in servers, home appliances and industrial equipment.
Toshiba - TC78B025FTG
The cooling fans used in servers and other must be small and rotate at high speeds with uniform accuracy. Uniformity is best achieved by using a speed-feedback method to suppress fluctuations in rotation speed caused by changes in the power supply voltage and load. Until now, this has required the use of microcomputers, but Toshiba’s new solution achieves flexible rotation speed control without external microcomputers by incorporating a non-volatile memory (NVM). This allows easy system configuration and supports motor speeds from hundreds to tens of thousands of rotations per minute (RPM) especially as Toshiba’s intelligent phase control (InPAC) motor drive technology realizes efficient driving across a wide rotation range without requiring adjustment.
The device operates from a power supply in the range 4.5 V to 16 V and provides a sine-wave drive with 150-degree commutation. Industry-leading low ON resistance of 0.2 Ω (typ.) (total of high and low sides) reduces the IC’s self-heating during operation, thereby extending support to large current drives. Speed is controlled by a simple PWM signal or an analog voltage input. In built protections include thermal shutdown, over current protection and motor lock detection. The device is housed in a VQFN24 package measuring just 4 mm × 4 mm × 0.9 mm.
In addition, the TC78B025FTG implements a 1-Hall drive system and current sense resistor-elimination system (Advanced Current Detection System - ACDS) to reduce the number of external components and contribute to space saving on PCBs.
Mass production started in April.
