Active-Semi announced the first member of a new family of PAC® high-performance motor controllers with the PAC5523 IC. It is supported by an Evaluation Kit (EVK) and accompanying firmware for easy and fast evaluation of advanced motor control solutions.
The new PAC5523 contains the highest-performance MCU found in an integrated motor control and driver product on the market. It contains a 150 MHz Arm® Cortex®-M4F MCU with 128 kB FLASH, 32 kB SRAM and an integrated Floating Point Unit (FPU) with Digital Signal Processor (DSP) instructions for highly efficient implementation of motor control and drive applications. The MCU also contains 4-level code protection, a cache for high-speed FLASH access, ECC for SRAM data and a CRC engine.
The PAC5523 also integrates highly-optimized peripherals specifically designed for BLDC motor control applications.
The 70 V PAC5523 is optimized for battery-powered and other BLDC applications up to 48 V. Integrated with the high-performance MCU is the power management, gate drivers and signal-conditioning for 3-phase inverter applications. The PAC5523 may be directly supplied with a battery of up to 20 or higher voltages using the 70 V DC/DC Buck or SEPIC controller Multi-Mode Power ManagerTM (MMPM). The PAC5523 implements a Total Hibernate ModeTM which manages battery life and system efficiency by reducing quiescent current to 18 µA.
The Application-Specific Power DriversTM (ASPD) integrates 70 V/1.5 A gate drivers for high power applications with 2-level dead-time protection for the external MOSFET-based inverter. The Configurable Analog Front-EndTM (CAFE) contains 3 Differential Programmable Gain Amplifiers (PGAs), 4 single-ended PGAs, 10 comparators, buffers and DACs that can be used for signal sampling and filtering for the control applications, minimizing the need for external components.
In a small 6 mm × 6 mm QFN package with all of the integration, the PAC5523 can realize an extremely small BOM and physical design size for compact BLDC battery-powered applications.
The PAC5523EVK extends the PAC® family of evaluation kits (EVKs) enabling fast prototyping for various applications including power tools, garden tools, telecom fans, battery-powered vehicles, drones, radio controlled cars, and general-purpose BLDC applications. Along with Active-Semi®’s motor control firmware and IP library, the PAC5523 will simplify system development with sensored and sensorless FOC and sensorless trapezoidal motor control applications for high-voltage battery powered applications.
The PAC5523EVK1 Evaluation Kit. |
PAC5523 IC and PAC5523EVK1 are available from leading distributors.
