American Bright's Full Line of RGB with Built-in IC Devices
American Bright BL-HBGGAJX32K-3-TRB BL-HBGR32L-3-TRB-8 BL-HJTGTBT39P-TRB BL-HRGB32K-3-TRB BL-HRGB32M-TRB BL-HRGB39P-TRB
Integrated circuit features self-detection signal
American Bright introduces a full line of addressable RGB LED devices with built-in IC. This intelligent LED device integrates RGB chips and a control circuit into a single and compact package, available in 5050, 3528, and 4020 (side-emitting), suitable for indoor and outdoor, gaming machine, and all kinds of entertainment lighting. The controlled integrated chip features self-detection signal, support for continuous oscillation, and pulse width modulation (PWM) output that can maintain static screen. These new devices have a low power consumption of 0.2 W (max: 1 W), applied voltage of 5 V and an operating temperature –40 °C to 80 °C. The emitted red, green, blue can achieve various color mixes with 8-bit (256 level) color set with 5-bit (32 level) brightness adjustment.
American Bright выпустила полную линейку RGB светодиодов со встроенной микросхемой
The RoHS-compliant RGB LED chip is well-suited for infrared and vapor phase reflow solder process and automatic SMT pick and place equipment. This new PLCC RGB device features a water clear lens and is ideal for a multitude of applications including indoor and outdoor commercial and residential lighting, light bars, and gaming equipment.
Features and Benefits:
  • Self-detection signal
  • Refresh rate of 400 cycles
  • 8-bit (256 level) color set
  • 5-bit (32 level) brightness adjustment
  • Low voltage .2 W power consumption
  • Built in support for continuous oscillation
  • Available in 5050 and 3528 (top-emitting), and 4020 (side-emitting) packages
Application:
  • Full color display
  • Gaming Machines
  • Soft light bar and rope lighting
  • Large LED display and backlighting
  • Decoration and entertainment lighting
  • Indoor and outdoor commercial and residential architectural lighting
List of RGB LEDs:
Part Number Category Size
BL-HBGGAJX32K-3-TRB PLCC-4 5050
BL-HBGR32L-3-TRB-8 PLCC-6 5050
BL-HJTGTBT39P-TRB PLCC-4 4020
BL-HRGB32K-3-TRB PLCC-4 5050
BL-HRGB32M-TRB PLCC-4 3528
BL-HRGB39P-TRB PLCC-4 4020
