Silicon Carbide Power MOSFET C3M Planar MOSFET Technology N-Channel Enhancement Mode
Wolfspeed C3M0016120K
Wolfspeed extends its leadership in SiC technology by introducing the industry’s lowest RDS(ON) SiC MOSFET at 1200 V in a discrete package. Designers can reduce component-count by moving from silicon-based, three-level topologies to simpler two-level topologies made possible by the improved switching performance. Using the separate Kelvin source pin can further reduce switching losses by as much as 30% compared to the traditional 3-lead TO-247 package. Featuring the lowest available on-resistance combined with a low gate charge, the C3M0016120K is ideally suited for three-phase, bridgeless PFC topologies as well as inverter and charger applications.
Wolfspeed - C3M0016120K
Features
  • Industry-leading 16 mΩ RDS(ON)
  • 1200 V VBR (minimum) across entire operating temperature range [-40 °C – 175 °C]
  • +15 V gate drive voltage
  • Low-impedance package with Kelvin source pin
  • > 8mm of creepage/clearance between drain and source
  • High-speed switching with low output capacitance
  • Fast intrinsic diode with low reverse recovery (QRR)
  • Easy to parallel and simple to drive
Target Applications
  • Solar and Energy Storage Systems
  • Electric Vehicle Charging
  • Uninterruptible Power Supply (UPS)
  • Motor Control and Drives
  • Switched-mode Power Supplies (SMPS)
