MAX40056 provides 0.3 percent accurate, full-scale direct winding current measurement, over 4 times faster than competition
Designers can now improve motor efficiency and reduce vibration using the MAX40056 bi-directional current sense amplifier with patented pulse-width modulation (PWM) rejection from Maxim Integrated Products. This high speed, wide-bandwidth amplifier extends Maxim's industry leadership in precision, high-voltage current sense amplifiers into motor control applications.
Creating a motor control system requires precise current sensing and measurement of motor winding currents. A commonly used approach is to infer winding currents by performing ground or supply referenced measurements in the bridge circuit. Direct winding current measurement is a simpler and more accurate method, but the implementation is challenging due to the high common mode swing of the PWM signal. Adoption of this approach has been limited by poor PWM rejection and slow settling speed of existing solutions.
MAX40056 rejects PWM slew rates of greater than 500 V/µs and settles within 500 ns to provide 0.3 percent accurate, full-scale winding current measurement. The patented PWM rejection scheme achieves 4 times faster settling time than competitive offerings, allowing motor control designers to increase drive frequency or decrease minimum duty cycle without sacrificing measurement accuracy. Higher PWM frequency smoothes out the current flow and reduces torque ripple, resulting in more efficient motor operation. Accurate winding current measurement at low duty cycle helps reduce or virtually eliminate vibration when the motor is running at a slow speed. MAX40056 has a wide common mode voltage range of –0.1 V to +65 V and a protection range of –5 V to 70 V to ensure the inductive kickback does not damage the IC. With bi-directional sensing capability, it is ideal for DC motor control, base station, datacenter, battery stack and many other applications which require precise current measurements in noisy environments.
Key Advantages
- Fastest Settling Time:
Patented technique rejects common mode PWM signals and yields fastest settling time within 500 ns.
- Highest Accuracy:
Accurate direct motor winding current measurement at 4 times higher PWM frequency or 4 times lower duty cycle than competitive offerings.
- Increased Performance:
- Improved motor efficiency and reduced vibration.
Availability and Pricing
- The MAX40056 is available at Maxim's website for $1.19 (1000-up, FOB USA); also available from authorized distributors
- The MAX40056EVKIT evaluation kit is available for $69
The MAX40056EVKIT Evaluation Kit. |
