The IL3865PE Is designed for next-generation RS-485 buses
NVE Corporation announced it has expanded its popular line of isolated transceivers with a part that is compatible with next-generation RS-485 buses.
3.3 Volt Buses
The new IL3685PE is compatible with 3.3-volt buses, has one-fifth unit loading to support up to 160 nodes, and 16.5 kilovolt bus ESD protection. It’s perfect for industrial control networks and DC-DC converter-powered buses.
True 8 mm Creepage
The unique wide-body SOIC is JEDEC-compliant, but unlike other “wide” SOICs, it has true eight-millimeter creepage.
Exceptional Specifications
Key IL3685PE features include:
- 3.3 volt bus
- 40 megabits per second data rate
- One-fifth unit load (supports up to 160 nodes)
- 2500 volts isolation
- 44000 year barrier life
- 16.5 kilovolt bus ESD protection
- Thermal shutdown protection
- –40 °C to +85 °C temperature range
- VDE V 0884-11 and UL 1577 pending
- 0.3-inch True 8™ millimeter 16-pin SOIC package
A Growing Product Line
NVE’s growing line of RS-485 isolated transceivers is the broadest in the industry, including various speed grades; low-power versions; up to 6 kilovolt isolation; and wide-body, narrow-body, and QSOP packages. All types are in stock for immediate delivery.
Available Now
The IL3685P is in stock for immediate delivery, priced at $3.55 each in 1000-piece quantities.
