Dialog Semiconductor Launches Configurable, High-Frequency Sub-PMICs Powering Latest Mobile Processors
Dialog Semiconductor DA9217 DA9220 DA9121 DA9122
The new power management family reduces solution size up to 40 percent, with less than half of the external components of competing solutions
Dialog Semiconductor introduced a new power management product family of four new sub-PMICs that offer best-in-class transient response and in-circuit digital programmability, in a smaller form factor than current market solutions.
Dialog Semiconductor - DA9217, DA9220, DA9121, DA9122
The new product family of Buck converters, which consists of the DA9217, DA9220, DA9121 and the DA9122, represents Dialog’s first sub-PMIC family with a 4 MHz switching frequency that reduces inductor size and height to allow use of smaller external components. The devices are ideal for ARM® Cortex™ based multi-core application processors and high-performance SoCs, FPGAs and GPUs, which enable developers to fit a 6 to 10 Amp power solution into limited board areas of next-generation devices spanning smartphones, tablets, notebooks PCs, DSLR cameras, solid state drives and more.
The devices drive higher efficiency without sacrificing functionality, simplifying complex system sequencing with digital programmability and configurability, for a seamless interface to the system microcontroller depending on the system requirements. The devices can support a single output up to 6 Amp / 10 Amp or dual outputs up to 3 Amp /5 Amp per output, making it ideal for the latest 7 nm based SoCs.
Leveraging Dialog’s power conversion prowess, the devices were optimized for users requiring high current with maximum efficiency. The sub-PMICs can run from a single cell Li-ion battery, 3.3 V or 5 V power supplies. The I2C interface enables dynamic voltage control to optimize power savings and performance, while the fault protection features also provide overvoltage, overcurrent and thermal shutdown protection.
