GLF's Introduces Ultra-High-Efficiency 4.5A Two-Input Power Mux for IoT Applications
GLF Integrated Power GLF74130
New IQSmart™ IC load switch designed for smart devices with backup power source; low ON resistance and ultra-low OFF leakage extend battery life; tiny WLCSP space-saving package size
GLF Integrated Power introduces the GLF74130, a two-input Power Mux IC that offers significant efficiency improvement over traditional diode-based solutions. The tiny (1.27 mm × 1.67 mm) Wafer Level Chip Scale Packaged (WLCSP) Power Mux IC provides automatic/manual selection between two 1.5 V to 5.5 V input power sources with up to 4.5 A continuous output current. The device’s small footprint and industry-leading combination of low RON (20 mOhms), low supply current (4 μA), and ultra-low standby current (50 nA) offer an exceptional solution for smart IoT devices and IoT tracking systems.
GLF - GLF74130
“The driving force behind GLF’s innovations in load switch design is to satisfy the market demand for extended battery life in wearables and IoT devices,” said Eileen Sun, President, and CEO at GLF Integrated Power. “The GLF74130, a two-input Power Mux applies our industry award-winning high-efficiency technology to replace the power-wasting diode circuits typically used to support primary and backup power sources.”
The GLF74130 supports both automatic and manual selection of power input, saving external components and GPIO that would otherwise be needed. The Device also features high ESD withstand capability (6 kV HBM and 2 kV CDM) to assure reliable operation.
