Teridian 78M6618 Energy Measurement SoC
Teridian Semiconductor 78M6618
Teridian Semiconductor today announced the launch of its new energy measurement system-on-chip (SoC), the 78M6618 (6618), for use in data center power distribution units (PDUs) and applications in the smart home, including intelligent power strips and circuit breaker panels. The new chip is the industry’s first and only SoC that enables power metering, monitoring and intelligent relay control of eight single phase outlets simultaneously. In addition, the 6618’s unique ability to monitor and control eight channels at once can be extended to 32 or more channels by connecting multiple chips together.
Teridian система на кристалле - счетчик электроэнергии
The latest addition to Teridian’s new energy measurement product family, the 6618 adds a new level of ‘intelligence’ to PDUs that will enable the reduction of drastic failures and critical downtime by allowing administrators to better understand the power that is being used in the data center.
“When even one minute of downtime can equal millions of dollars in losses, quantifying and understanding minimum and maximum energy requirements of servers, power supplies, PDUs, and communication equipment on a per-outlet level is key,” said Jay Cormier, Teridian vice president and general manager, Energy Measurement & Communications. “We offer the additional advantage of an extremely clear value proposition over competing solutions as we can monitor eight outlets simultaneously with a single chip. Alternative solutions require eight chips and a microcontroller to achieve the same results.”
78M6618 Functional Block Diagram
Teridian 78M6618 Functional Block Diagram
Click to enlarge
Teridian 78M6618 Energy Measurement SoC Features
  • <0.5% accuracy over 2000:1 current range and over temperature
  • Self calibration to facilitate rapid design time and optimal manufacturing efficiencies
  • 32-bit compute engine, an MPU core and FLASH memory
  • Up to eight (8) outlets individually measured by one IC
  • Can be extended to 32 or more channels by connecting multiple chips together
  • Provide complete energy measurement and communication protocol capability
  • Single Converter Technology
  • 22-bit delta-sigma ADC
  • 10 analog inputs
  • Precision voltage reference
  • Digital temperature compensation
  • Power factor measurement per outlet
  • Intelligent switch control per outlet
  • Complete energy measurement host interface firmware available
The 6618 offers unprecedented accuracy of better than ±0.5% over a 2000:1 dynamic range with self calibration to facilitate rapid design time and optimal manufacturing efficiencies. The 6618 is a highly integrated, single phase, eight-outlet, PDU power measurement, and monitoring SoC, which includes a 32-bit compute engine, an MPU core and FLASH memory. Teridian’s patented Single Converter Technology™, with a 22-bit delta-sigma ADC, 10 analog inputs, precision voltage reference, and digital temperature compensation, supports a wide range of PDU metering applications with very few external components. A complete array of ICE and development tools, programming libraries and reference designs enable rapid development and prototyping of power and energy measurement devices.
teridian.com
