TI's Dual-output 200-ma Power Supply Improves Picture Quality In AMOLED Displays
Texas Instruments TPS65137
Texas Instruments introduced a new 200-mA dual output power supply designed to provide improved picture quality for active matrix OLED (AMOLED) displays that require positive and negative supply rails. The TPS65137 uses a low dropout (LDO) post regulator for line and load transient response with minimum output voltage ripples to provide stable picture quality.
Texas Instruments - TPS65137
With its wide input range of 2.3 V to 5.5 V and small solution size of 3-mm × 3-mm QFN package and small external component count, the TPS65137 is suited for AMOLED displays in portable devices, such as mobile phones and smartphones. Order samples of the TPS65137 today: www.ti.com/tps65137-preu.
Key features and benefits of the TPS65137
  • Wide input voltage range of 2.3 V to 5.5 V allows the device to accept higher positive input voltages than the positive output voltage and still maintain accurate regulation of one percent of the positive output voltage.
  • LDO post regulator for positive output to provide line and load transient response with minimum output voltage ripples to provide stable picture quality.
  • Advanced power save mode with out-of-audio control reduces switching frequency as the load current decreases and maintains high efficiency over the entire load current range without audible noise.
  • Digitally programmable negative output voltage from –2.2 V to –4.9 V in digital step.
