Targeting industrial and energy applications with motor drives for air conditioning, home appliances and factory automation, as well as power control in charging stations, energy storage systems, and power supply units STMicroelectronics’ ...
Empower Semiconductor unveiled the largest silicon capacitor in its ECAP product family for high frequency decoupling. The new EC1005P is a single 16.6-microfarad (uF) capacitance device suitable for the most demanding power integrity targets as ...
Diodes Incorporated introduces a new 12-channel, constant-current LED driver, the AL58221 . It features 12 open-drain outputs that are rated to 24 V and sink up to 60 mA of high-accuracy current with a fast transient response. The ...
ROHM has developed an ultra-compact 1.8 V 5 V, rail-to-rail CMOS operational amplifier (op amp) the TLR377GYZ . It is optimized for amplifying signals from sensors such as temperature, pressure, flow rate, used in smartphones, small IoT devices, ...
Murata Manufacturing Co. Ltd is expanding its range of multilayer ceramic capacitors (MLCC) with the groundbreaking new GRM188C80E107M and GRM188R60E107M. Designed to cater to the continuous demands for miniaturization in servers, data centers, and ...
Alpha and Omega Semiconductor Limited (AOS) introduced its AOZ8S205BLS Series transient voltage suppressor (TVS) diodes. These ultra-low capacitance TVS diodes are designed to meet the increasing ESD protection needs in today’s sensitive ...
The L99H92 automotive gate driver from STMicroelectronics provides an SPI port for programming and diagnostics, a charge pump, protective features, and two additional current-sense amplifiers for system monitoring. Containing two high-side and two ...
By Gareth Halfacree While the long-lived Z80 continues on in Z180 and eZ80 forms, the standalone DIP-packaged variants' days are numbered. Zilog has announced it is halting production of its standalone DIP-packaged Z80 CPU models a move that ...
Industry-low 160 nA current consumption improves power savings in consumer and industrial equipment ROHM has developed a linear operational amplifier (op amp) LMR1901YG-M featuring the lowest current consumption in the industry. This makes it ideal ...
With a high-performance 160 MHz RISC-V core and a second low-power 20 MHz companion core, this tiny board targets smart home projects. Seeed Studio has launched a new entry in the XIAO family of small form factor microcontroller development boards, ...
