Atmel Introduces Two High-performance, Cost-Efficient RF ICs for Car Access Systems
Atmel ATA5830 ATA5780
ATA5830 and ATA5780 are the next generation of highly-integrated monolithic RF transceiver and RF receiver devices with leading RF performance in sensitivity and power consumption
Atmel: ATA5780, ATA5830
Atmel Corporation, a leader in microcontroller and touch solutions, today introduced the next generation of smart RF devices for the automotive and consumer markets, enabling RF systems with high performance and application simplification. Committed to the automotive market, the Atmel ATA5830 and ATA5780 are the next generation of monolithic RF transceiver and RF receiver devices with worldwide leading RF performance such as sensitivity and power consumption. The multiband devices are designed for the ISM frequency bands in the ranges of 310 to 318 MHz, 418 to 477 MHz and 836 to 928MHz, and are the ideal solutions for today’s demanding automotive remote keyless entry (RKE), remote start, passive entry go (PEG), and tire pressure monitoring systems (TPMS).
The monolithic devices combine a highly advanced RF receiver or transceiver block with a proven Atmel AVR microcontroller core. This enables the devices to poll multiple application channels to support, for example, the RKE/PEG, Remote Start and TPMS system with a single IC instead of having multiple ICs, which results in a very cost efficient solution.
"Atmel is an automotive expert and has over 25 years of automotive design expertise. The introduction of these new products continues demonstrating Atmel’s commitment to the automotive industry," said Klaus Herhoffer, Car Access Marketing Manager, Atmel Corporation. "In addition, these new products provide designers the flexibility to optimize their RF solutions for TPMS, RKE, and PEG without system performance sacrifices. These new RF devices further solidify Atmel’s leadership in the automotive RF market."
The ATA5830 and ATA5780 are pin-compatible devices to ensure maximum reuse of development effort for 1-way and 2-way systems. Based on this pin-compatibility feature, the printed circuit board design can be the same for both the unidirectional and bidirectional car access system, which is a unique selling point in regards to variants, stock of replacement parts and cost savings.
These products are ideal for all car access applications due to their excellent RF performance, high flexibility and modular concept. These benefits, combined with a very high-integration level, result in the requirement for less than half of the external components of previous products on the market. "Use of the devices will enable the most cost-efficient car access system solution possible," said Klaus Herhoffer.
The highly sensitive devices (typical -109dBm, 10kBps Manchester data rate, FSK modulation with +/-10kHz frequency deviation, IF bandwidth 165kHz) provide a high image rejection and excellent blocking performance (typical 64dBc at 1MHz, IF bandwidth of 165kHz) for the customer application. The transceiver's maximum power-down current of 600nA ensures that customers enjoy maximum battery life and battery size is kept to a minimum.
atmel.com
