Linear Technology Corporation announces the LT3042 , a leading-edge, ultralow noise, ultrahigh power supply ripple rejection (PSRR) low dropout voltage linear regulator. Its unique design features ultralow spot noise of only 2 nV/√Hz at 10 ...
Linear Technology announces the LTC7138 , a 140 V input-capable high efficiency buck converter that delivers up to 400 mA of continuous output current. It operates from an input voltage range of 4 V to 140 V, making it ideal for a wide range of ...
Linear Technology announces the LT3790 , a synchronous buck-boost DC/DC controller that delivers up to 250 W of power with a single IC. Its 4.7 V to 60 V input voltage range makes it ideal for a wide variety of automotive and industrial ...
Linear Technology Corporation announces the LTC3371 , a highly integrated general-purpose power management solution for systems requiring multiple low voltage power supplies. The device features four synchronous buck converters, each powered from ...
Linear Technology launched the LTM4625 , a 5 A, 20 V IN step-down uModule® (micromodule) regulator in a 6.25 mm × 6.25 mm × 5.01 mm BGA package which, with a few passive components, fits in to 0.5 cm 2 on a double-sided PCB. Like ...
Linear Technology Corporation introduces the LTC4121 , a constant- current/constant-voltage 400 mA charger for Lithium-Ion, LiFePO 4 and lead-acid batteries. The LTC4121’s high efficiency, synchronous step-down topology accepts a wide 4.4 V ...
Linear Technology announces the LTC6268 and LTC6269 , FET-input single and dual op amps, which deliver outstanding performance for high speed and high dynamic range transimpedance amplifier (TIA) and buffer applications. With just 3 fA bias current ...
Linear Technology announces the LT3999 , a monolithic push-pull isolated DC/DC transformer driver with two 1 A current limited power switches. The LT3999 operates over an input voltage range of 2.7 V to 36 V, is targeted for power levels up to 15 W ...
Linear Technology introduces the LTC2946 , a high or low side charge, power and energy monitor for DC supply rails in the 0 V to 100 V range. An integrated 0.4 % accurate, 12-bit ADC and external precision time base (crystal or clock) enables ...
Linear Technology introduces the LTC2645 , a quad-channel 12- bit/10-bit/8-bit PWM-to-voltage output digital-to-analog converter (DAC) with 10 ppm / C reference. These parts convert PWM input signals to 12-bit accurate, stable, buffered voltage ...
